• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
Question 3600xt Asus tuf x570 no signal fully lit dram led debug light is on
Jun 12, 2020
Hi I'm trying a new build and I can't get a display at all. Not even bios. I am running a ryzen 3600xt, Asus tuf x570, vega64, raidmax 1200 80 gold. I'm getting power to everything but no display. I've disassembled and reassembled to no avail. I don't want to throw it out the window...........
boju
Polypheme
Ambassador
Dram points toward memory. What configuration do you have? Two memory modules in the 2nd and 4th slot from cpu. Check they're seated properly and dimm latches lock in on each memory side.
Could possibly be bent cpu pins causing memory issues.
Jun 12, 2020
Cpu is brand new no bent pins. I have Corsair vengeance lpx 2x16 on 2nd and 4th slot. I've tried moving the memory around but the same thing Everytime. It all powers up with no output signal and the dram debug led is lit immediately. I've even tried different ram but the result is the same
boju
Polypheme
Ambassador
I mean bent pin or pins from installing it. It can happen if not careful.
GarrettL
Notable
Dec 4, 2019
1,499
332
1,190
41
I have the Asus TUF x570 as well.
Are you 100% positive the memory is seated properly? I really don't like the dimm slot locking design used. I prefer the old school type with locking tabs on each end. But this board has the slide lock style on lower side. PIA.
Reactions: boju
Rogue Leader
It's a trap!
Agree, they have the same kind of slot on my Crosshair VI, when I rebuilt my system on it I almost made the mistake of not having the memory fully slotted due to this goofy setup.
