Hello,
I recently purchased a new 15.6" Toshiba laptop for college with the following specs:
i7-3610QM
8GB RAM
750GB HDD (5400 RPM)
Nvidia GeForce GT 630m - 2GB (Optimus)
The most demanding thing I will probably be doing is running multiple VM's of different operating systems for my classes. I haven't installed VMWare yet as I'm in the middle of a co-op term, so I figured I'd try to stress-test it with some gaming.
When gaming with the dedicated video card active, the CPU reaches temperatures of around 90C, sometimes dipping down to the mid-80's. For some reason none of the software I've tried gives me a temp. for the GPU.
I've read that Ivy Bridge CPU's tend to run hotter than SB ones did, and the chip is apparently rated for 105C, but this still seems really high. The air coming out of the side vent feels like it's burning when you put your hand in front of it.
The CPU idles at around 45C which seems standard.
Since I'm currently paying tuition/rent, I'll need this laptop to last a while. A bit of gaming here and there is probably unavoidable - will regular gaming sessions eventually cause damage to my machine if it continues to run at this temperature?
Would I be better off returning this model for a 2nd gen. i7 if I need it to last?
Thanks very much for any advice.
-Bob
i7-3610QM
8GB RAM
-Bob
