$399 Computer + 9500GT card = PSU problems?
nicholasny
Hello Community,
I'm going to be getting this Gateway DX4800-05e ... http://www.newegg.com/Product/Product.aspx?Item=N82E16883113094 ... and plan on buying and putting in an NVIDIA 9500GT graphics card.
My question: Am I going to have to replace the 300w stock PSU to get enough power?
I'd prefer not to, as I'm not 100% confident in my ability to mess around in the box without killing the computer, and I'm not sure how much room there's going to be in the case anyway.
Thanks to anyone who takes the time to reply and help me out!
MGDJoker
237
I would replace the powersupply in almost any Bigbox brand. The reason they are so cheap is cause they get mass amounts of gray market product of the lowest quality. The failure rate for an Emachine PSU is around 60%. Gateway used to make Emachines. Now i believe Acer owns the 2 companies. Maybe they stepped it up on quality. Still i would replace the PSU, if u can and the case or PSU is not proprietary.
uncfan_2563
904
yeah i agree with MGDJoker. Even if the new psu u get isnt from a top brand, it will still be tons more reliable.
and if you do it careful, don't touch what you don't know, you will be fine. removing the psu just requires the removal of some screws in the back of ur pc, unplugging the cables, putting the new one in.
MGDJoker
237
Maybe if this was 2002 and you were running a Radeon 9200. Its always safe to have more power than u think you would need. Plus the overall quality of the stock PSU is just trash.
It would most likely run with the 300watt for sure. In contrast that 300watt PSU under load will not stay consistent. Even my PC Power and Cooling 750 drops in power when under full load. If u strain the 300watt it will take a dump and you will risk smoking your motherboad.
Im just talking from experience. I've provided computer customer service for several years now and seen just about every possible scenario happen to a computer with hundreds of different hardware configs.
You'll be fine with that PSU, just don't try to run any games.
nicholasny
MGD, you make some compelling points, and there's a nice looking 430w power supply from Thermaltake on Amazon for $36, so I'm going to scoop that up.
@invisik: I'll be watching movies and playing noncutting-edge games (WoW and Civ4 mostly)
And I think I'm going to pick up a 4670 w/ 512mb made by MSI, looks like better value than the 9500GT...
