3D modeling and texturing workstation build / 2000-2500 budget / preliminary research question
therdt
APPROXIMATE PURCHASE DATE: ASAP- emergency - within the week
BUDGET RANGE: $2000-$2500
SYSTEM USAGE:
Maya
Zbrush
XSI
Photoshop
PARTS NOT REQUIRED:
Monitor, speakers, sound card, mouse, keyboard
COUNTRY OF ORIGIN:
United States
MAIN CONCERN:
Am I on the right path starting my research with a single xeon cpu, and a w5000 or W7000 card, or is an i7 and a Quadro the better choice to start researching?
EXTRA INFO;
I had a negative experience trying to save time by buying a precision from dell at a discount. Very bad experience. Now I am manning up and looking to build my first workstation, and would like to hear opinions on what direction I should take my research, moving forward.
First and foremost, this is for work. Editing, modeling, and texturing very high resolution 3D Models in Maya, Zbrush, and Mari, while also editing big files in Photoshop. Rendering, and particle simulation is secondary, while gaming is in a distant third place.
http://www.thefoundry.co.uk/products/mari/system-requirements/
http://pixologic.com/zbrush/system/
After doing prelim research am I on the right path with a single xeon cpu, and a firepro card? I used to think that a quadro was the say all end all, but after looking around I am wondering if a w5000 or even a w7000 might not be a strong choice. I figure that once these variables are established then I can base everything else around those two components.
I am much more artist than technician, and so I definitely need to lean on some support from the people who know better. Thank you for sharing your knowledge.
Travis
Hi
When it comes to Pro CAD and 3D modeling there are great HP Workstations CTO Models - my advise to You is to look for HP Dealer and you can costumize the build for you need and budget.
F.e. there are 3 range of Workstations - Z230 , Z620 , Z880
in Z820 :
- you can have up to 2 CPU`s Intel® Xeon® Processor E5-2697 v2 12C 2.70GHz
- up to 16 DIMM Slots for DDR3 ECC Memory
- Supports up to 512GB using LRDIMMs
- Graphics
Professional 2D
NVIDIA NVS300 512MB Graphics XP612AA
NVIDIA NVS 310 512MB Graphics A7U59AA
NVIDIA NVS 315 1GB Graphics E1U66AA
Entry 3D
NVIDIA Quadro 410 512MB Graphics A7U60AA
NVIDIA Quadro K600 1GB Graphics C2J92AA
Mid-range 3D
NVIDIA Quadro K2000 2GB Graphics C2J93AA
High End 3D
NVIDIA Quadro 6000 6GB Graphics WS097AA
NVIDIA Quadro K5000 4GB Graphics C2J95AA
AMD FirePro W7000 4GB Graphics C2K00AA
NVIDIA Quadro K4000 3GB Graphics C2J94AA
NVIDIA Quadro K6000 12GB Graphics C2J96AA
And this is the most amazing option :
High Performance GPU Computing
Support Notes
NVIDIA Tesla C2075 Compute Processor - QB035AA - See note 1
NVIDIA Tesla K20c Compute Processor - C2J97AA - See note 2
NOTE 1: Up to two C2075 processors are supported.
Only supported with the Z820 1125W Chassis.
Must have add-in graphics card in addition to the C2075.
Supported Graphics cards are Quadro 600, Quadro 2000, and Quadro 6000.
Not supported in a configuration that has BOTH E5-2687 Processors and Quadro 6000 Graphics.
NOTE 2: Up to two K20 processors are supported. Only supported with the Z820 1125W Chassis. Must have add-in graphics card in addition to the K20. Supported Graphics cards are Quadro K600, Quadro K2000, and Quadro K5000.
So in simple English you can costumize you HP Z820 Workstation from 2760 $ up to 9999 $ or maybe more :)
http://shopping1.hp.com/is-bin/INTERSHOP.enfinity/WFS/WW-USSMBPublicStore-Site/en_US/-/USD/ViewStandardCatalog-Browse?CatalogCategoryID=VIoQ7EN6bWsAAAEu6P84OQ28&jumpid=cp_r163_us/en/pc_comm/workstations/wsfamily/buynow
If you need Custome HP CTO Pm-me i`ll see what i can do :)
