Hello guys, have a corsair 460X rgb case with 3 SP120 fans 3pin type. Ive heard that they are a bit noisy, but they are a lot more than i could expect. Also i have watercool corsair h100i v2 and i had to place radiator at the front, so 2 of SP fans are intake through radiator atm. I know it would be better to swap them to any other 4pin, but for now cant do more.
So, 2 of these fans are connect to pump and somehow they can work quieter than 3rd one, which causing high temperatures btw. I tried to do same thing with 3rd fan that connected to the motherboard, but in bios i cant set any of max/min fan duty below 60.
So my question is - how does 3pin fans work? It should be running at 1400rpm and no less, but it is 1100/1200 rpm, and my pump somehow can even slow down them
Anyway, if ill buy 4pin fans for radiator, i dont want sys fans to be so noisy. Is there any way to slow down them?
