G
Guest
Guest
Archived from groups: rec.games.frp.gurps (More info?)
In 3rd Ed. they cost A LOT.
In 4th Ed., they are cheaper, but they seems to be unable to exploit
the Swing damage: they all use Thrust damage!
I noticed this while converting a 3rd ed. "Super" to 4th ed... Is
there any way in 4th ed. to represent something like this:
"A sword protruding from the hand, which is able to inflict
swing/cutting OR thrust/impaling. It uses the Melee Weapon: Sword
ability to strike or parry. Reach 1."
I supposed I could build it from Claws(Talons) or Strikers, and just
say the use of the Medium skill Sword instead of the Easy skill
Brawling was compensed by Sword Techniques, the different reach
(please note that's "Reach 1", NOT "Reach C,1"!) and the remote
possibility of using it as a tool.
My problem, now, is the Swing damge... Am I missing something?
Any suggestion (official or unofficial) will be welcome.
Also: what if the character could convert the sword (let's say) in a
Flail (which uses the skill "Melee Weapon: Flail")?
Korin Duval
"Truth requires a great amount of courage;
Fiction requires a great amount of maturity."
Korin Duval
