3rd monitor out of range
cheatsparkvideos
40
So i was tying to connect my third monitor but once i connected it it was out of range. Is there a way to fix that ? i have AMD Radeon HD 5700 Series graphics card, intel i3-4330 3.50 GHz
The card supports has 2 DVI port one HDMI and one DP.
Any advice ? I have ITX motherboard
The hd 5000 series needs an ACTIVE displayport to whatever you want adapter to work with more than 2 screens.
cheatsparkvideos
40
May you explain or leave a link to where its explained in details ?
It's as simple as use any of the ports for 2 monitors and then use the displayport with an active adapter for the thrid one.
cheatsparkvideos
40
And whats an active adapter ?
