I was looking at my psi and noticed there was a cable that had two 4 pin connectors with 12v. Just wondering what it was for before I turned anything on. Can someone please help?
All about the various PC power supply cables and connectors http://www.playtool.com/pages/psuconnectors/connectors.html
Here you go.
It's the cable you want to be sure of the routing for before mounting the motherboard. Usually, once the MoBo is in place it's a real PITA to get plugged in.
You can use the 8 pin it has 2 CPU power connections .
Connectors
1 x Main connector (20+4Pin) 1 x 4+4 Pin ATX12V / EPS12Vnot needed if you use 8 pin. 1 x EPS 12V 8-pin ATX12V / EPS12V😀
Up to 6 Peripheral (2x Triple Molex 4pin)
Up to 9 SATA (3x Triple SATA Cables)
1 x 6-pin PCI-E
1 x 6+2-pin PCI-E
