4+4 pin cable to 8 pin single pin
angelion
137
So my Power supply got 4+4pin for my mobo and i got an extension 8 pin eps12v Extension 45cm bitfenix will this work i plug both 4pin connectors to that single 8pin extension and then plug in to the mobo?
Thanks
PSU
extension
angelion
137
Ok then i l plug the 1 4+4pin to single 8 pin extension and then plug it to the motherboard 8 pin thanks :D
