I've got a Silverstone FSX 600w PSU and an Asrock Z170 gaming ITX motherboard but I'm slightly confused by the psu cables.
It's both 8 pin on the psu and 8 pin on the motherboard but the cable that came with the psu is 8 pin one end (the square and rounded pin shrouds match the psu socket perfectly) but the other end is 4+4. However, the rounded and square male shrouds don't match up with the socket even when used together and are in a different layout to the normal 8 pin socket.
Now the motherboard states you can use 4 pin connector by just using half the socket but I just need some clarification. Should I just put half the socket in that does fit along pins 1 to 5 on the board or still put both 4 pins into the socket. (The other 4 pin plug does fit as rounded shrouds will fit into the square sections) and I've seen when searching this it's so they are backward compatible?
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
It just seems a bit wrong to put sockets on against configuration? Is it correct like this?
