So I am about to build a new PC. It will be i7-6700k with asus z170a MOBO. I just bought G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory. After doing so, I decided i wanted to have 32gb and bought the exact same pair from the same vendor again (less than 24hrs later). I understand that it is best to try and get a kit of ram, but there are some determining factors i am confused about. This is a multi-part question really:
1. Does it matter if I use 2 pairs or a pack of 4 if the board is dual channel anyway?
2. Can the XMP profiles be activated for each pair seperately, or will i have to hope that they match and that 1 profile works.
3. If i have to get a new kit instead, Is 2x16 noticeably faster than 4x8?
BTW another arguement for 2x16 vs 4x8 is that youll have 2 more slots to upgrade later, but that doesn't make sense if your supposed to buy your ram as a kit instead of 2 pairs lol.
4. LAST PART: Do i have to get ram on the approved list of the motherboard? It seems there really are only 4x8 3200mhz kits on there, so if 2x16 is faster, id have to go down to 3000 according to them. (i know not a big deal, just saying)
Ive just seen a lot of conflicting information.
THANKS!
THANKS!
