ralphyboy Honorable Dec 15, 2012 4 0 10,510 Dec 16, 2012 #1 Hello The 4 pin ATX 12V cable from my power supply is too short. Is there an extension cable available?
ralphyboy Honorable Dec 15, 2012 4 0 10,510 Dec 16, 2012 #3 Can you tell me where I can find it? Upvote 0 Downvote
scout_03 Titan Feb 18, 2010 30,587 324 107,640 Dec 16, 2012 #4 one http://www.amazon.com/Cable-CB-P4-P4-extension-Connectors-inches-connector/dp/B004TNHW64 two http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=4640 three http://www.newegg.com/Product/Product.aspx?Item=N82E16812706005 Upvote 0 Downvote
ralphyboy Honorable Dec 15, 2012 4 0 10,510 Dec 16, 2012 #5 Thanks so much! I did a search before I submitted, but nothing came up. Thanks again. Upvote 0 Downvote
scout_03 Titan Feb 18, 2010 30,587 324 107,640 Dec 16, 2012 #6 sometimes changing a term and gogle find it for you. Upvote 0 Downvote
ralphyboy Honorable Dec 15, 2012 4 0 10,510 Dec 23, 2012 #7 I contacted Coolmax and they sent me an extension from a peripheral to a 4Px1. Not what I needed. Bought the correct one from Amazon. Upvote 0 Downvote
