I think I have a pulled a real bonehead maneuver. I was moving a complete previously working PC from one case to another including mother board, drives, PSU, cards, everything. When I powered it back up the green LED on the mother board lit but the fans did not run, there was no noise from the hard drives, and there was no POST. I unplugged everything and started over by plugging in just the motherboard power connections. When I tried starting it again the CPU fan ran but there was no post and nothing on the monitor. Although I cannot be sure, I think the 4 pin ATX12V had been plugged in 180 degrees from what it should have been when I first started it. When I went to plug it the second time it seemed to plug in differently but I am only going on memory. I know what you thinking. That would be impossible because of the way it is keyed and that is what I thought too. Unfortunately I tried both positions with the power off and it does go in either way.
My question is as follows. If it was plugged in backwards what ended up being destroyed? Just the MB, or the MB and CPU. What about drives including a brand new never even formatted SDD, the cards in the slots, or the PSU?
If it was plugged in backwards I would have thought the 12V pins would have been just connected to ground and creating a short with no damage to the board and only possible damage to the PSU but I am no expert on the internal configuration of the motherboard. Is there anyone with real knowledge on this that could advise me?
