4 pin front panel connector on gigabyte b250 ds3h
MEL1315
292
Hi guys, i was assembling my new build. Do you know where the 4-pin single connector from front panel connect on this motherboard? It has too many pins for front panel connector. Any help please?
Guys, I've sorted it out. No it's not audio or usb 2.0 port. It is the front panel connector itslef. I plugged it in ports 1,3,5,7 in the earlier diagram by SkyNetRising.
Thank you guys.
Read manual - page 16.
https://www.gigabyte.com/us/Motherboard/GA-B250M-DS3H-rev-10#support-manual
Like i said, i don't have separate cables like power led, power switch, reset switch etc. All i have is a 4pin (in a single line) unmarked (except a white dot, probably indicating +) cable. So where should i plug it?
Have you identified which cables are for audio and usb2 and i assume are plugged into the motherboard? What other features does your case have at the front besides audio and usb?
Hard to say where this cable belongs without knowing what it connects to
Thank you guys.
