Does an adapter exist that allows a mobo's 4 pin header to control a 3 pin fan via PWM?
If not, to what (if any) extent are 3 pin fans controllable when plugged into a 4-pin mobo header?
Also, what should I look for when getting y-splitters for fans? Are splitters that just split a 4-pin into 2x 4-pins okay or should I be looking at the ones that also have a supplemental Molex power connector to the PSU?
