So I looked around the forum and counldnt find this answered anywhere. I am making my first watercooling build on a phantom 820. I am not a big fan of fan controllers you put in 5 1/4" and i would like to use the fan controller that comes with the phantom 820. only problem is that i have 10 fans altogether and 7 of them are noctua pwm fans. Is there a way to connect them to the phantom 820 that only supports 3 pin fans? the phantom 820 has 4 channels with 15W per channel. the other 3 fans are cooler master 3 pin fans...
