4 Pin rgb fan header isnt on my asus motherboard
Jun 15, 2018
i just bought a Cooler master masterbox 5 rgb lite and there is a 4 pin rgb fan header that i cant connect to my Asus p8Z77-V Deluxe. dosent that motherboard support rgb or can i just get an adapter of some kind? i have a old i7-3770k. the RGB hub from cooler master costs 10$ less than the case, so for my its really espensive. iam considering buying a i5-8600k with a ASUS ROG Strix B360-G Gaming, S-1151 motherboard. if i do that will everything be fine and i can control my fanes and ligtning. ive read that the masterbox supperts asus aura so is it best to buy a motherboard that is asus auro compatable?
Unfortunately the Asus p8Z77-V Deluxe doesn't have a dedicated motherboard Asus Aura RGB connector.On the other hand your contemplated upgrade ASUS ROG Strix B360-G has RGB header which is compatible with Cooler Master RGB fans and RGB cable.
Cooler Master MasterBox Lite 5 RGB Case Review >>https://www.thinkcomputers.org/cooler-master-masterbox-lite-5-rgb-case-review/4/
