Question 4 Problems - GPU sagging/CPU Power cord/Case has 3.1 USB/CPU fan replacement
zstrange20
45
My Computer parts: https://au.pcpartpicker.com/list/9bWDn7
Photos: View: https://imgur.com/a/v783NtA
My PC
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor
MB: MSI MPG X570 GAMING PRO CARBON WIFI ATX AM4 Motherboard
RAM: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory
SSD: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive
GPU: Gigabyte GeForce RTX 2070 8 GB GAMING OC Video Card
CASE: Cooler Master MasterCase H500M ATX Mid Tower Case
POWER SUPPLY: Corsair HX Platinum 850 W 80+ Platinum Certified Fully Modular ATX Power Supply
GPU SAGGING
Looks like its sagging and i want to get a part for the gpu to be at the front is this good for the gpu and my case to fit? and it wont sag with that on right? also will this downgrade my pcie if do this? and would it fit?
COOLER MASTER MCA-U000R-KFVK00 Universal Vertical VGA Card Holder
CPU Power cord not long anuff
The CPU Power cord from power supply would not go around the back of the case since it was too small its a 6pin
Anyone know any extender power cpu cord or a longer one that i can plug into my power supply into the motherboard.
It has to go over the GPU and MB
My case has 3.1 USB input
My case is Cooler Master MasterCase H500M and it has a 3.1 usb input at the front of the case but i can not plug it into my motherboard MSI MPG X570 GAMING PRO CARBON
is there away i can get something to plug that in without making it slower?
CPU fan replacement
I had alot of trouble getting the cpu fan onto the motherboard it was really hard to get on since im new to pc building and i dont know how hard or how soft you have to put it on soo alot of stress now the troubling part is to get it off once i get a new cpu cooler since i know its not gonna be good for the AMD Ryzen 9 3900X CPU since its most likely gonna get hot with the stock cooler on it. and i heard people have taken the cpu off with the fan aswel soo its abit stressful since all this is REALLY expensive since if i broke something i would most likely have to get a replacement and probably take a year or 2 to replace if i did break something
Sorry for spelling errors just need a little help I'm new to PC building I'm only 18
Thanks for those that understand and helped!
