4 two pin plugs on Rosewill Stealth case
krb1945
59
I purchased a Rosewill Stealth atx case that has the usbs 2.0 and 3.1 new gen and audio on top front of case.
The cable bundle that comes from the module is pretty much self explanatory except for 4 black two pin connectors that are unmarked. Each of these connectors are about .30 x .43 inch in size. I have misplaced/lost the manual that came with the case.
I've visited the rosewill site and tried to download their manual but it says it downloads in pdf but it contains 0 byte after download, no information.
I'm hoping someone can tell me what these plugs connect to.
Many thanks for assistance. Ken
If the manual didn't help. i'm at a loss.
Still, i had the impression, Rosewill is not a bad company, service-wise. Why not ask them via email directly?
While waiting for an answer or suggestion, I kept searching for the manual. I finally found it. It appears these connectors are for fan speed control A and B.
Just like the frog getting swallowed by the Heron, "never give up", the search!
ragnar-gd, it must be real slow, I waited for several minutes.
Anyway I said finding the manual helped me, but it didn't. Being overly anxious to get this system on line... I misread some of the information.
The case manual "did not" address these 4 two pin plugs. Now Im back at square one. It still looks, without dissembling that pwr sw/usb/audio module, like they may have something to do with the two fan speed switches on top of the case.
Problem is I can't see where they might plug into the MSA Z170-A pro MB.
If anyone out there has a suggestion, I sure could use the help.
yep I like there cases I rebuilt, upgraded 4 of my systems using them in the past 18 months. This is the only one, and it is the most recent one that has those four plugs. I'm going to call 'em monday. Ken
