I recently built my own pc, assembled 3 days ago, and I think I have an issue with the temps. I have an i5 3570K, no overclocking, in a master cooler elite mini itx case (120mm and 80mm intake fans, 120mm internal fan, and the only thing moving air out is the fan on my corsair psu). At idle in RealTemp, my cores generally stay around 40 degrees, sometimes going as low as 32, sometimes as high as 46. The load for this period has been ranging from 0-25%. As I am typing this the load is 10% and the temps are 38 degrees roughly. Is this normal, and can the system stay like this for years without any detriment to its lifespan or capabilities?
I had also ran a Prime95 blend test for 10 min (I just got it and its the best I can do atm) and saw my temps hover around 80 degrees, with one core hitting 84. Load was at 100%, obviously. Is this anything to be worried about?
I feel paranoid that I may have set the cpu cooler wrong, but I do not want to go back and redo it (especially since its a stock cooler and came with pre-applied thermal paste, I've never had to apply the stuff myself before.) unless someone can tell me that the temps I have are indicative of an improper seating of the cpu cooler fan.
Thanks in advance. (In case it helps, I have a z77-n gigabyte mobo, 8gb crucial memory, HD 7850 2gb gpu, and 600w corsair psu)
