$400 CPU,Mobo,Ram,Cabinet
karamvirk
Approximate Purchase Date:
2 or 3 days
Budget Range: Rs 20,000 / $400
System Usage from Most to
Least Important: HD Movies, General Use, Gaming (Lowest settings will do)
Are you buying a monitor: No (Got LG 23" Full HD Monitor)
Parts to Upgrade: CPU,
Mobo, RAM, Cabinet, PSU, HDD
Do you need to buy OS: No
Preferred Website(s) for Parts:
www.flipkart.com
Country - Chandigarh, India
Parts Preferences: Any
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Additional Comments: MS Expression Web, Gaming even lowest settings will do as I am not buying GFX card now but I will surely consider it in future.
Reason for Upgrading: 6 year old P4 really needs to rest now.
My build, please check it for compatability and suggestions.
AMD 3.6 GHz AM3+ FX4100 Processor Rs 6,900
http://www.flipkart.com/amd-3-6-ghz-am3-fx4100-processor/p/itmd54hrgmx6xwhn?pid=PSRD54HRFDKY69XH&ref=dd3a79c3-04d0-46db-b1f7-6485f9955802
ASUS M5A88-M Motherboard Rs 5,500
http://www.flipkart.com/asus-m5a88-m-motherboard/p/itmd4g9hfhnaeaxv?pid=MBDD4G9GZFPG5PK9&ref=08c36bab-5bf0-47df-a78e-10476ed34b7f
Cooler Master Elite 310 Cabinet (Blue) Rs 2,000
http://www.flipkart.com/cooler-master-elite-310-cabinet-blue/p/itmd5xzyexrzww5a?pid=CABD7QFG9HYGXDGB&ref=e09114f3-ad76-44a4-8073-ead7964dc4f8
Corsair Vengeance DDR3 4 GB (1 x 4 GB) PC RAM (CMZ4GX3M1A1600C9) Rs 1,800
http://www.flipkart.com/corsair-vengeance-ddr3-4-gb-1-x-gb-pc-ram-cmz4gx3m1a1600c9/p/itmd2rypbx4eehaf?pid=RAMD2RYPMVWCEK6E&ref=b32094d0-e472-4b16-a9ac-dc7178f82aa5
I already have 1TB Ext Hdd so I dont want to spend much on Hdd. Will buy Hdd and PSU from some local store. So leaving that budget of 16k remains for above 4 items. Thank you for your time.
bigcyco1
Champion
AMD MOBOS I RECOMMEND TAKE YOUR PICK ALL ARE SOLID GOOD BOARDS!See if you can find any of these and switch your CPU to a 965BE then your good to go.
MOBO:GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514#top
MOBO:ASUS Sabertooth 990FX AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736#top
MOBO:ASUS M5A99X EVO AM3+ AMD 990X SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131754#top
MOBO:ASRock 990FX Extreme3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157281#top
MOBO:GIGABYTE GA-990FXA-UD5 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128509#top
MOBO:ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280#top
karamvirk
Thanks for the reply
But you forgot/misunderstood my budget limitations. Mobos you suggested are 10k or more and 965 is also priced at 10k, so my 20,000 ($400) budget is already finished and I am yet to buy 4 other items (RAM,Cabinet,PSU,HDD). This is the reason why I am trying to stick to micro-ATX mobo.
bigcyco1
Champion
Well it should work don't expect to much out of it though but it shouldn't be to bad of a build good luck and i hope you enjoy it :)
Similar threads
