Question $4000 dollar budget. Custom Hardline Water tubing Workstation help.
Aug 25, 2019
My computer has recently broke, and I am in need of a replacement. I do a lot of cad and video editing, primarily 4k. I overclock a lot, with my old pc having a 6700k at 4.5ghz. I would like to be doing custom hardline, as my case is designed for it, and I believe it to be quite useful for overclocking.
Approximate Purchase Date: About 2 months
Budget Range: 3750-4000
System Usage from Most to Least Important:CAD, 4k Video editing, very light gaming.
Are you buying a monitor:
Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: N/A, All
Parts Preferences:
AMD CPU
Overclocking: Yes
SLI or Crossfire: No
Your Monitor Resolution:
4k
Additional Comments: I use fusion 360, as well as premier pro, and have an Engineer's background.
And Most Importantly, Why Are You Upgrading: My ex-desktop has recently stopped working, and I need a replacement, and seeing as my old one was very weak, I have decided to just all out buy a new one.
Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
Thermaltake Tower 900 Black Edition Tempered Glass Fully Modular E-ATX Vertical Super Tower Computer Chassis CA-1H1-00F1WN-00
https://www.amazon.com/Thermaltake-Tempered-Vertical-Computer-CA-1H1-00F1WN-00/dp/B01N1GP2GZ/ref=asc_df_B01N1GP2GZ/?tag=hyprod-20&linkCode=df0&hvadid=198093101467&hvpos=1o1&hvnetw=g&hvrand=11021870017545495366&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9032339&hvtargid=pla-384220317545&psc=1
LordVile
Admirable
Yes
Parts Preferences:
AMD CPU
Overclocking: Yes
4k
Can I ask what you’re using for video editing software wise? Also overclocking Ryzen systems isn’t that useful. You don’t gain much and with the 3000 series CPU boost algorithms match or outperform OCing without instability issues. Hardline would just be for looks and is the budget for that in the 4K or seperate? It included please say how much you’re intending to spend on the custom loop.
g-unit1111
Here you go, this gives you $700 left over for monitor and peripherals:
PCPartPicker Part List
CPU: AMD Threadripper 2990WX 3 GHz 32-Core Processor ($1693.64 @ Amazon)
CPU Cooler: Corsair H115i PRO 55.4 CFM Liquid CPU Cooler ($139.42 @ Amazon)
Motherboard: ASRock X399 Taichi ATX TR4 Motherboard ($299.00 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3600 Memory ($204.99 @ Newegg)
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive ($169.89 @ OutletPC)
Storage: Seagate BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive ($79.99 @ Newegg)
Video Card: XFX Radeon RX 5700 XT 8 GB Video Card ($399.89 @ OutletPC)
Case: Phanteks Enthoo Pro M TG ATX Mid Tower Case ($99.99 @ Amazon)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($129.91 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($139.99 @ Other World Computing)
Total: $3356.71
Generated by PCPartPicker 2019-08-26 17:52 EDT-0400
If you want to save money you could switch to the 16 core 2950X and not lose anything.
Latest posts
