450w power Supply enough?
just_play_it_cool
i bought a power supply from EVGA; 450 BT Bronze Certified power supply. its my first time building a PC and i Dont know if it can comfortably handle, GTX 1060 3GB DDR5, Ryzen 1600, 16 Gb ram, 1 tb, and 1 180Gb M.2 SSD.
Gpu 120w, CPU 95w, rest 60W, <300W, times 1.25 , 450 W is fine:) however, that PSU is not very reliable. Get a Seasonic full modular one if possible, good promotion @newegg right now :)
I think the PSU you have is fine IF you are not overclocking anything. Consider that a basic PSU, not fit for anything other than running things at stock speeds. Make sure you have good airflow through your computer, heat is not good for entry level components and PSUs can get hot fast.
