loganoftw :
Where to put power sw, reset sw, hd led, +p led, -p led on h110m-e/m.2 same thing with the fans ive been stuck on this forever
At the bottom-right corner of your motherboard,
you will see a 9-pin header labelled as
F_PANEL. The pinouts would look like this:
[pre]
[o][o][o][o][ ]
[o][o][o][o][o]
[/pre]
Plug your 460X's front panel cables, i.e., the 2-pin
Power SW, the 2-pin
Reset SW, the 2-pin
H.D. LED, the 1-pin
+P LED, and the 1-pin
-P LED, like this:
[pre]
+PLED <--+ +-->
-PLED
