Specs: Mobo - GA-Z87X-UD4H
CPU - I5 - 4670K
Case - Corsair 300r Carbide
Cooling - Kraken X40 (single 140mm)
GPU - MSI 770 TF Gaming
RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB)
PSU - SeaSonic M12II 850
-----This is my first time overclocking-----
So ive been trying many different configurations with my 4670k to get the most out of my system. I tried running the cpu at 4.5ghz but even after cranking the VCore up to 1.300 it was still unstable and wouldnt run Prime95 for more than 30seconds.
Ive settled for 4.2ghz and am currently running the VCore value at 1.25 to check for stability. So far all the voltages havent lasted more than a few hours in Prime95 at the most intensive stress test.
Im running CPU-Z, CPUID Hardware Monitor and Prime95
My CPU temps never really rise above 73c
My questions; What VCore value is still relatively safe for this 4th gen high heat haswell cpu? (i read 1.19....but im way past that...lol)
What other settings should i be tweaking in the bios (possibly something im missing all together?)
Any other tips or suggestions that can be provided to achieve 4.2ghz...or even higher, preferably
CPU - I5 - 4670K
