4770 help
dvvel
4
Hello guys, a week ago l bought the new gigabyte ati 4770 1gb, yes l know it the 1gb ram is a waste but it was really cheap ;o
But the problem is that l get really low fps. (avg. cod5, fallout3 fps @ 1960x1080 all maxed, no AF is 20-30).
The only drivers l have installed are from ati, the power supply is fine too, the only thing l can think off is the motherboard.
Help please?
mb:http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=2567
SiSoft Sandra Lite is a great utility to find out thing or two about your equipment (even stuff your manuals never tell!).
http://www.sisoftware.net/
@ wa1
lowering resolution doesnt help
@ Mactronix
amd 4400+ @5ghz
4 gb ddr2 ram
460W ps
win xp 32
I reinstalled xp, but it was the same, l dont think vista/7 would do better, but maybe its worth a try?
