Looking for some quick help
My i7 4790K just arrived. I do plan to OC, and my mobo is an Asrock Z97 Pro4.
The case is a Cooler Master Masterbox Lite 5 RGB:
http://www.coolermaster.com/case/mid-tower/masterbox-lite-5-rgb/
I'm using 2 fans in the front (aigo120 rgb's), I can add a 3rd if needed.
So, I'm looking for advice on cpu cooling.
Do I:
Go with a large air cooler (Noctura,etc), a Radiator with (2) 120m Fans on back of case, or place a 240/280 radiator/fans on the front of case???
Would like to take the OC, as far as I can stable. Thoughts?
I have read the other posts on this forum regarding the 4790K.
Thanks!
Do I:
Thanks!
