I'll try to keep this short. Here's facts:
4970k stock (4.4 boost) seated in
Asus Hero VII m/b
H110igt with aftermarket Phanteks fans (http://www.newegg.com/Product/Product.aspx?Item=N82E16835709036&cm_re=phanteks_140mm-_-35-709-036-_-Product) high pressure fans (Corsair fans are SO noisy) set as exhaust with 2 970s in sli, blower style fans
Phanteks Primo Case
Anyways...I left the original paste on the h110igt when I got it. I haven't bothered overclocking yet because of temps. In push configuration, as stated above, during games I'd hit around 55-60c, and Aida stress would hit 65ish.
I wanted to play around with running the cooler as an intake, and during this I cleaned out the time to reseat with some Arctic Silver paste. Anyways...It ran maybe 2-5c hotter, and my gpus were warmer a few degrees.
So today I decided to reseat the cooler and I now have the fans set as exhaust, and they are pulling through the rad. I reseated with this paste a few times, as I hit 80c on Aida once. I've now got the cpu idling around 35-38c, and during a recent game (gta5) I hit 67 on the hottest core, sitting around 60c for the most part.
These temps seem really high to me. I'm only running 1.2v on the stock 4.4 boost. I've built a few dozen machines and haven't had this issue creep up before where I just couldn't get decent temps.
My kid's machine in the same house (usually 27c in the summer with ac on) has a stock 2500k on a h100, and their idle is 29 with peaks of near 50-55c.
Any advice? I'm not liking this Arctic Silver I'm using...it's very liquidy. Should I get a thicker paste? The stock paste that came with this h110i gt was pretty thick.
Thanks for any advice!
BTW: I use the "pea to half pea" method to mount the cpu plate.
Asus Hero VII m/b
Phanteks Primo Case
