4790K stock settings runs HOT
i7-4790K
5
Hi, this 4790K is at stock settings and includes an aftermarket Hyper 212 EVO cooler.
Is the Vcore (1.4) too high at the stock turbo settings? I get 96 degrees Celsius after two minutes in prime95. At idle temps (35) and gaming (65) it's fine.
Ah, Gigabyte Z97 boards have the same issue, you must update your BIOS as well in order to fix that issue. But as soon as you flash it, it will work perfectly.
Ok, I'll try going in my BIOS settings. Thanks.
I actually have a Z97 motherboard (Gigabbyte GA-Z97X-UD3H-BK).
I updated the BIOS to F6 (the latest version) and the Vcore is now 1.23 @ 4.4GHz and 5 minutes of prime95 I'm at 78 degrees max.
I couldn't be happier. Thanks for the help.
