Although AIDA64 is good for
stability testing, it's poorly suited for
thermal testing.
Since everyone tests their rigs using X stress software at Y Ambient temperatures with Z measuring utilities resulting in CPU or Package or Core temperatures, it's impossible to compare apples to apples. This is why processor temperatures are so confusing.
Prime95 Small FFT's is the standard for CPU thermal testing, because it's a
steady-state 100% workload. Prime95's default test, Blend, is a cyclic workload for testing memory stability, and Large FFT's combines CPU and memory tests. As such, Blend and Large FFT's both have cyclic workloads which are unsuitable for CPU thermal testing.
Other stability tests such as Linpack and Intel Burn Test have cycles that peak at 110% workload, and are also unsuitable for CPU thermal testing. The software utility OCCT runs elements of Linpack and Prime95.
Shown above from left to right: Small FFT's, Blend, Linpack and Intel Burn Test.
Note the
steady-state thermal signatures of Small FFT's, which allows accurate measurements of Core temperatures.
Shown above from left to right: Small FFT's, Intel Extreme Tuning Utility CPU Test, and AIDA64 CPU Test.
The "Charts" in SpeedFan span 13 minutes, and show how each test creates different thermal signatures. Intel Extreme Tuning Utility is also a cyclic workload. Although AIDA64's CPU test is steady-state, the workload is below Thermal Design Power (TDP), which is insufficient.
Please download
Prime95 version 26.6 -
http://windows-downloads-center.blogspot.com/2011/04/prime95-266.html
Run only Small FFT’s for 10 minutes.
Use Real Temp to measure your Core temperatures, as it was designed specifically for Intel processors: Real Temp - http://www.techpowerup.com/downloads/2089/real-temp-3-70/
Also, what is your ambient temperature?
Please read this Tom’s Sticky:
Intel Temperature Guide -
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
Thanks,
CT
