Hi all, first post on Tom's Hardware
Long story short, have a 4790k cooled by a h80i liquid cooler. After my PSU failed, it fried the cooler, so I got a replacement one and this time, got it fitted by a professional (first time was a DIY)
Only change is he made the fan intake from outside of the case, and exhaust inside (it's the only fan functioning in the case, other than the GPUs stock cooler)
Temperatures are now much higher than they were pre-replacement, idle and load.
-Idle, 32-39c
-Load (farcry 4, ULTRA, 1080p, for 3 hours) 62-69c
-Prime 95 (max temp stress test) 91-98c around 6 seconds into test
I don't care for benchmarking, so prime 95 doesn't bother me. I would just like to know what could be causing the spike in temperature. A list of things I've done since my concern are as follows
- used arctic silver 5 replacement thermal paste
- I actually lost one of the waterblock mounting screws, so theres 3 tightly secured instead of 4, but the temperatures remain the same even when I had 4 on the replacement cooler, it's currently the only variable
- I've gotten rid of boost, so it runs at 4.00Ghz load, rather than 4.4
- Set the coolers fans to 100% speed when temps hit 60c
- Ensured correct thermal application
- Maintained Cpu's stock voltage
is 69c steady playing a game like farcry 4 negligable? Or should I be considering remedies to that sort of temperature? Is the missing mounting screw affecting arctic silver 5's performance? Like I said, the temps were the same even before the missing screw.
Cheers!
-Idle, 32-39c
Cheers!
