4850 running hot in Antec 900
perfectpoo
8
So my new pc runs great, but my gpu is running too hot for my comfort. It is running at 85-90 degreec under moderate load. (Eve Online game). It idles around 55 degrees.
Case is setup with:
2 120mm in the front as intakes.
Side 120 enermax fan is an intake.
top 200mm exhausts.
Rear 120mm exhausts.
The gpu itself is set to run at 65% and it keeps it down, but it is loud as heck. I'd like to run it at a lower percentage, but I can't keep it cool at 65.
Does any one have this case that can recommend a better setup for me?
Extra info:
CPU runs at 28 degrees
Case temp is around 40 degree
No overclocking being done
faster3200
287
I would try a better cooler if you are really concerned. My guess is that the stock cooler just wasn't installed very well.
85C-90C isn't too bad under load. GPUs are designed to take a lot of heat so you are ok although this is the upper end of temps.
