Last night while using my 4870x2 perfectly fine sounded right, then I decided to restart my computer upon restart the fan on the video card sounded god awful. It is like a mix between a rattle and a grinding noise. I found out that if while it is on, at 60% fan speed that if I stop the fan for a second with the end of a pencil eraser it will go away, but upon restart the noise is back. I was wondering if anyone has any suggestions.
Second if I can't get an RMA if it is bad, I was thinking about after market coolers for my 4870x2, but the only true air cooled solution is the Accelero Extreme which will not fit into my case as I have a Cooler Master Storm Scout, so I was wondering if there was any coolers that have come out that are smaller, and wouldn't increase the length of the card so that I can fit it into my case. I would go water, but it is utter expensive and I am a little short on cash, I have maybe 100 dollars to spend on a new cooler if I need one. Any suggestions would be appreciated on both questions.
Thanks,
Heavy_ Metal
Thanks,
Heavy_ Metal
