4Gig system - 2 x (2 x1gig) or 4 x 1gig - Bit Confuzed!
martinuk
8
Looking to get 4 gig of memory for a new Vista system. Looking at ebuyers website i see they offer 2x1gig kits and 4x1gig kits. Now i would assume the 4x1gig kits would be what i was looking for but then i noticed the latencies on the 4x1gig kit is listed at 5-5-5-18, and the latencies on the 2x1gig kit are listed at 5-5-5-12.
Here are links for the two items im referring to:
2x1gig kit http://www.ebuyer.com/UK/product/98710
4x1gig kit http://www.ebuyer.com/UK/product/130328
The price would be about the same either way so which should i go for? I would assume getting two lots of the lower latency stuff, but do the 4x1gig kits offer some other performance benefit?
Thanks.
Let me re-clarify my question:
Im getting 4gig regardless, but should i get 2 sets of the (2x1gig) kits (as ebuyer shows them with lower latencies) - or should i get the 4x1gig kit. The price of buying 2 lots of the (2x1gig) kit, against the price of the 4x1gig kit is about the same is why i am asking :).
Thanks.
It looks like a tossup. But if I w3ere RAMing up from scratch I'd actually get 2 x 2gig instaed of four chips. Some mobos have a little problem with all 4 slots used, further this would leave slots open for futuer upgrades.
If you plan on upgrading to 8 Gig later get the 2gig x 2, if not get 2 1gig x 2 sets. Both options will let you run your memory in dual channel mode.
Don't forget to make sure:
1) You will be using 64-bit Vista
2) Your MB chipset supports 8GB or more RAM
3) Your MB BIOS has a "memory remapping" function
If your system is missing one or more of the above, it won't be able to use more than about 3GB+ of RAM. The hardware uses up a number of addresses downward from the 4GB mark, and the RAM gets to use what's left over (often something like 3.25GB).
You wouldn't even notice the difference between 5-5-5-18 and 5-5-5-12.
And for a new system, if you know you want 4 GB now, I agree with others. Get the 2x2GB and leave the other slots free, if your motherboard supports it.
-TyShoe
