Question 4k display for office work (Excel, Power bi & tableau) with i7-4790 CPU @ 3.60GHz (AMD Radeon R7 200 Series & Intel(R) HD Graphics 4600 workable?
Jul 23, 2020
16
So my plan is to buy a new Acer monitor of 4k for office and personal use https://www.amazon.in/gp/product/B08J921K8C/
The Acer monitor detailed specifications are here https://www.displayspecifications.com/en/model/9aec1e79
below are the specifications of GPU, CPU and current monitors. Mention to me if I need to post other info from the CPU-z report.
My workstation specifications are https://pastebin.com/t9Bx7qpP
usage or programs, Office tableau power bi, None of graphics stuff.
Note- checked my CPU display cable is working on bo
My personal specifications are https://pastebin.com/VCpYiMyR
Usage only one game Dota 2, but I am willing to play on 1080p if possible on the new 4k monitor or lower setting otherwise I will play it on my old 720P monitor.
Lastly, if it's not compatible then I was just going to replace my 720p Samsung with any one of these https://www.displayspecifications.com/en/comparison/fdd519e973
Questions:-
  1. Is the new monitor compatible with both of my PCs? and is it compatible at least with the work one?
  2. Is there a better 4k monitor within the same price range.
The best connection for a 4k monitor is via displayport.
That will allow you to run 4k resolution at 60hz.
If you need to use hdmi 1.4 , the best you can do at 4k I think is 30hz which you will find to be no good at all.
Ohh okay and the monitor has only one display port, which isn't an issue for work pc but my personal PC has an HDMI slot rather than a display port so my home PC will work with 30 fps with this setup.
If I lower the resolution will normal windows work with 60hz as normal for personal PC with HDMI?
My main concern is about my Low end GPUs on both PC will normal windows at 4k work?
Can anyone still answer me if the low end gpus of both PCs will able to handle 4k monitor? For programs like tableau, excel power bi, they are analytical program not kuch graphics rendering.
