thecrazyman :
Thanks for that! I didn't buy it purely just for 4k, I just wanted a smart TV that would be able to double as a monitor and the 4k one seemed like the best future proof option. UltraHD Blu-Rays aren't out yet are they?
There may be a couple out, but there's not many at all, it'll take some time.
jossrik :
Ya, that doesn't count, he's not using the TVs built in decoder for 4k content, he's using his PC which has the correct codecs for 4k, it's just that 4k content is very very rare right now. I know, I got my 4k setup well, started it like 7 months ago, bought my 49in 4k monitor, has HDMI 2.0, so all good, then had to trade my AMD video cards which didn't have HDMI 2.0 for my nice Nvidia ones, just got my second 980Ti a couple days ago actually, the upscaled video from across the room looks great, but up close you can see a lot of artifacting, and the games look great, but man do they take some horsepower to run well. I've been patiently awaiting good 4k content for a while now.
I knew he was using the PC to watch it, I just thought it would be useful to have that information as well.
Meanwhile, I still play games in 720p! (Oh! The horror!)
Seriously though, and this is purely my opinion, I'm not judging anyone, I personally see almost no reason to play any higher than the original HD resolution, not only does it require less horse power, it allows the components to run cooler, especially when you limit FPS to 40 which is fine for me, as long as it's at least 30. I don't see enough of a difference between 30 and 60 to care. Though to be honest I'm also used to older games with crappy graphics compared to today, and DOS games.
I will still admit though, 1080p is nice and clearer, and if my hardware could keep up, sure, I'd use it just for the sake of it, but otherwise, I really don't care either way. And 4K in my opinion is going to be a niche market, unless you're uber close to the screen/TV, the human eye isn't going to see a huge difference, unless you have a habit of zooming in on frames for screenshots or what have you, in which case, definitely better. That and the improved color on the UHD Blu-rays.
As I said, not judging anyone, not putting anyone or their equipment/preferences/opinions down, I mean no offense whatsoever, just my two (s)cents. If you like 4K, I say go for it.
Also thecrazyman, I'm glad your question has been solved, I definitely overlooked what jossrik found right off.
