4K Monitor Advice
James86
11
Hi,
I'm looking for a decent 4K monitor mainly for gaming. After reading many reviews, doing a bit of research and completely frying my brain I think I've narrowed it down to one of three choices:
The Asus PB287Q or;
The LG 27UD68P or;
The Iiyama GB2888UHSU.
What I'm asking for from you knowledgeable people is whether any of you have had experience with any of these monitors and, if so, how they've performed. Additionally, if anyone has a better suggestion for a 4k monitor for around £380 then I'm all ears.
Many thanks in advance for any help!
I hope this helps you narrow your choices more ""https://www.youtube.com/watch?v=YC-KHOKM7ck""
But personally I find LG better in the color reproduction but on the otherhand Asus will give you the ability to change your screen refresh rate from like 60Hz up to 120Hz
But what is more important than all of that is do you have graphics card that can run games in 4K ??
I'll give that a watch once home, don't think I can get away with it whilst at work.
I'll be using two Gigabyte GTX 970 G1's in Sli. From what I've read I should be able to manage 4k at 30- 45 fps with that but would likely drop down to 1440p for more intensive titles. As such, the Asus might be a good choice with the alterable refresh rate.
Thanks for the response!
