Question 4K monitor lag
wm3797
233
6
10,585
I connected a 4k HDMI cable from desktop to DELL S2722QC 4K monitor. Why does everything lag from mouse pointer to opening a simple File Explorer ? I installed all relevant DELL 4K monitor drivers already. This is the HDMI cable used.
ASUS PRIME Z390P
i7-9700K
no graphics card
What monitor were you working with prior to the DELL S2722QC? BIOS version for your motherboard at this moment of time?
Perhaps try and use DDU to remove all GPU drivers(AMD, Nvidia and Intel) in Safe Mode, then manually reinstall using the latest GPU drivers sourced from Intel's support site, here, in an elevated command, i.e, Right click installer>Run as Administrator.
Reactions: wm3797
Previously I used a 1080p ASUS MX279H. BIOS version is 2804. I even installed fresh windows in a separate ssd, same problem occurred. Maybe my motherboard old or ports don't support it ? Maybe my cable is missing some capabilities ?
