4k Monitor stuck in 1080p
Adam Hindle
52
I have a MSI R9 280x Graphics card with a HDMI lead connecting from that to my Acer 4k monitor. I have the latest drivers for both.
The issue is when i go to Control Panel > Display > Adjust Resolution it only shows 1920 x 1080?
Rather than showing 4k resolutions, and the picture quality looks rubbish because of this.
I can't seem to think of a reason why this is like this and was hoping for some help on a fix
Thanks.
I had a similar situation a while back when i ran my Gtx 780 with my 4K display, found that using a display port cable is much better and fixed the issue. (Also you can enjoy 60hz rather than the limited 30hz via HDMI)
How about the monitor setup? See that it's not forcing certain format to the image. I'm assuming you use HDMI cable connected to the gpu, right? Check through control panel/device manager if the card is connected right, and try disabling integrated graphics.-
Through control panel/device manager/graphics and here it must have 2 options, one is the gpu and the other one is the integrated gpu. Right click that option and disable.-
Whats your cpu?
My graphics card has two mini display ports, hdmi and DVI. And my monitor has HDMI, DVI and Display port
