T THEHIPPIEPROJECT Honorable Jul 24, 2015 83 0 10,630 Jan 15, 2018 #1 what cable or adaptor would i need as it does not take the same size cable as the ps4 monitor xb280hk ps4 pro
Glenwing Splendid Aug 8, 2015 3,201 347 25,990 Jan 16, 2018 #2 THEHIPPIEPROJECT : what cable or adaptor would i need as it does not take the same size cable as the ps4 monitor xb280hk ps4 pro You have the name of the monitor, it only has one port, is it that hard to find what kind of port it is? https://www.acer.com/ac/en/NZ/content/model/UM.PB0SA.002 Spoiler G-Sync monitors are intended for PCs. You need to use DisplayPort which is only found on PCs. HDMI to DisplayPort adapters will be limited to 4K 30 Hz. https://www.amazon.com/gofanco-DisplayPort-Converter-Compliant-Dual-Mode/dp/B01BXMOREI/ Upvote 0 Downvote
