Please tell me your 4K TV for PC monitor setting experience?
What low end 4K TV do you recommend?
How about Seiki SE39UY04 ? It is selling at Walmart for $340?
We have 4 HP Z800 workstations and bought 4 of the Seiki SE39UY04 UHD TVs to use as monitors. 3 of our systems have no problems, run at 3840x2160 and come out of sleep mode just fine. The last system always reverts to lower resolution and requires a restart to restore the 3840x2160. We tried everything and then realized that the working system are Windows 10 and the problem system is Windows 7. The problem system also had a ASUS GTX970 Strix video card, while the working systems had ASUS GTX 660Ti and ASUS GTX 760 video cards.We swapped the GTX660Ti into the Windows 7 system and it now works properly.
young707 :
How about Seiki SE39UY04 ? It is...
not for gaming.
just for use for PC computer use.
May be occasionally watching video online, such as Youtube
but just to replace small old 28" 1680 x 1050 resolution monitor
Do I need new higher resolution graphic card?
I have i7 16GB Windows 7. Thanks.
I am running Windows 7 at 64 bits. Check my system display adapters are
Intel HD Graphics 3000
Nvidia GeForce 6200 LE do not know if this has 128MB or 256MB memory.
how do I find out what is maximum resolution this graphic card supports?
What graphic card with much much memory should I get?
To take advantage of the 4K 39" TV for use as monitor at maximum 3840x2160 resolutions, what kind of low end graphic should I get?
Will be using for typical PC / text editing / email and sometimes youtube video. No gaming.
young707 :
