Hello friendly people,
I have an interesting opportunity to upgrade from my Asus 27" 144hz 1080p monitor (great lil unit) to a 4k TV or possibly use a 4k monitor.
Deal is this, I have $3200 store credit ONLY at a electronics store (JB for those that may know of them), I can not get multiple items, I can not get a gift card either, It is from a extended warranty claim that went completely pear shaped. So its either another Laptop to similar value or another big ticket item to the same value, ie a 4k TV
excuse the caps for the answers here, it just appeared easier to read, well for me anyway, Sorry if anyone struggles.
1. What Is Your Country Of Origin? AUSTRALIA
2. What do you plan to do with this monitor? GAMING, MOVIES
3. What resolution and screen size do you want? 27" and above + 4K,, PREFER 30" - 32"
4. What refresh rate do you want? AS MUCH AS POSSIBLE, ALTHOUGH OBTAINING 100 FPS AT 4K RESOLUTION WILL BE PRICEY (GPU UPGRADES). 60hz AS A MINIMUM
5. How much are you looking to spend? $3200 - ONE ITEM ONLY
6. Brands Preferred? AS LONG AS ITS A REPUTABLE BRAND AND AVAILABLE THROUGH JB HIFI , ANY DELL, ASUS, SONY.... SO ON AN SO FORTH
http://www.jbhifi.com.au/tv-lcd-led-plasma/3000-4000-price/
7. Brands Not Preferred? SEIKI, AND ANY OTHER "CHEAP" BRAND, YEAH JUST NO, PLUS THEY ARENT AVAILABLE TO ME
8. Are You Buying More Than One Monitor? POSSIBLE IF THE 4K AVENUE DOESN'T PAN OUT
9. How Many Displays Can Your GPU Support Maximum? And what GPU and driver version are you using if applicable? ONLY HAVE AN ASUS 2gig 770 DCU2 (WILL SELL AND UPGRADE TO 4GIG SLI 770 OR GO 780/ti WITH SLI OPTION FOR LATER, ALTHOUGH WHEN I HAVE MONEY FOR THAT THE NEW 8xx SERIES MAY BE OUT OR NEWS OF RELEASE SHOULD BE HERE)
10. What Port Do You Want To Connect To? DISPLAY PORT SEEMS TO BE MY ONLY OPTION FOR TRUE 60hz 4K CONTENT, UNLESS I AM MISTAKEN
11. Is This Monitor A Primary Display Or A Secondary Display? PRIMARY
12. Is This A Secondary Display For A Laptop? NO, DESKTOP SPECS BELOW
I'll try and stop yelling at you all now
Specs at present are
i5 4670k - @ 4.6 Ghz
MSI gd65 Z87 mobo
16gig G.Skill ripjaw Z 2400 memory
Asus DirectCU2 GTX 770 OC'd maxing at 1254Mhz
Samsung 840 ssd 250g - OS boot
WD blue 1T HDD
thermaltake toughpower gold 750W
LG Blu ray/DVD combo
8 x fans, 120mm + 140mm mix
Running Windows 7 premium
So, as I need to get the one item as close to the value as possible, a multi 1080 screen setup is not being looked at yet. If the single 4k solution doesnt pan out I'll just find someone that wants a new TV or laptop and trade for cash, although I will have to take a large hit as the $ amount for refund purposes is only $1600. its a massively long and complicated story that I wont go into any further than I have to, basically the lesson here is, always build your own
I have looked at a couple of TVs that I could pickup tomorrow, although I have a couple of concerns.
The following TVs look good with good refresh, but no Display port inputs 🙁 unless there is some other way of getting 4K res @ 60hz I am not aware of these could be a problem.
www.lg.com/us/tvs/lg-55LA9700-led-tv
www.sony.com.au/product/kd-55x8504a
www.samsung.com/au/consumer/tv-audio-video/television/uhd-tv/UA55F9000AMXXY-spec
And the monitors I MAY be able to order in, as long as they are available at the time for the store.
www.asus.com/Monitors_Projectors/PQ321QE/#overview
accessories.ap.dell.com/sna/productdetail.aspx?c=au&cs=aubsd1&l=en&s=bsd&sku=210-ACBW&redirect=1
Main concerns for TVs are;
1) No display port connections
2) Size, Not that its a deal breaker I will have to re arrange and get a new desk to accommodate a 55" screen
3) The 100hz refresh rate is only on 1080 content and drops to 30hz for 4k viewing
Monitor issues
1) refresh rates
2) input lag
3) stitched 1920 x 2160 screens, atleast with the Asus it is, not sure if that just adds an extra point of failure or is it all good.
Concerns for both,
1) Is 4K just too new for any major kinks to have been ironed out.
2) Waste of money just yet
3) What is the noticeable difference between 3840 x 2160 and 2560 x 1440 displays
Any advise you can give or any experiences with the tech you can share would be fantastic beyond belief,
Im not in a massive rush so can hold off for another month or two, which may change the outcome.
Hopefully Ive got everything and if I havent, please feel free to ask
Many thanks in advance and I appreciate the time you would have spent reading my novel
MSI gd65 Z87 mobo
WD blue 1T HDD
Monitor issues
1) refresh rates
2) input lag
Concerns for both,
