4k will not work stuck in 30 hz
Kold51
54
ok, so my monitor stuck in 30hz mod. I change the Dp from 1.1 to 1.2 manually on the Monitor with still no sucess of changing the 30hz mode. I still do not know what I am doing wrong. I got all the hardware to run 4k why won't it work
Gpu: Asus Titian X, Mobo: P8 z77 v pro, Cpu: i7 2600k. Monitor: ASUS PB287Q
That's awesome to find the solution. High bandwidth digital signal delivery has always had strict standard and requirements about cabling. Length is usually well defined and needs to be followed to make everything run perfectly.
Yah it was a cable issue, just not the one you would normally think about. You can only have a 10 foot cable on dp 1.2. Stupid as that sounds, I was using a 15 ft cable which was restricting my dp.
