4pin atx to SATA?
tolk
62
I'm trying to put together a machine from a few spares/old parts. I have one of these power supplies with one 8 pin ATX power cable being used for the motherboard, and one male 4 pin ATX power cable.
Is it possible to power a SATA HDD and optical drive from the 4 pin? If so can someone point me at the necessary adaptor/s? I'm UK based so accessible recommendations would be preferred.
You can't use that as it doesn't carry 5V, only 12V.
If that is the only available plug, your options are to get a splitter, or replace the power supply.
Splitters are dangerous because they make it easy to overload a power supply with too many devices. As long as you stick to low-power and keep the total consumption under the rating for the supply it is relatively safe.
If you mean the standard molex 4-pin, then yes. Don't buy a cheap adapter, as they are known for catching fire.
This is for a single drive:
https://www.scan.co.uk/products/startech-6in-15cm-4-pin-molex-(male)-to-sata-power-cable-adapter-converter
Here is a one for two, but they would have to be close by. Hopefully that gets you started in your search.
http://www.newegg.com/Product/Product.aspx?Item=9SIA67038W1990&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-Cables+-+Internal+Power+Cables-_-9SIA67038W1990&gclid=CPOIwY3hm84CFYGEaQodriYNIQ&gclsrc=aw.ds
It's an 4 pin ATX power supply cable rather than molex, i.e. this: http://img.misco.eu/Resources/images/Modules/InformationBlocks/1210/SRH/SRH-1/197691-StarTech-com-8in-ATX12V-4-Pin-P4-CPU-Power-Extension-Cable-M-F-03.jpg
I don't know if i can adapt to molex first and then from that to SATA as you suggested.
