Ok so i have 2 questions:
1) Can you plug a 4pin PWM fan into a 3pin voltage controller and will it work. The extra pin is just a speed control for the fan turning on and off really quickly to regulate the speed (as far as i can see). If i disconnect (or just not plug in) this pin will this fan work as a normal fan and respond to voltage control?
2) To prevent overloading the CPU fan header could i instead splice some cables and take the PWM feed off the header and send it to other fans to control their speed. Would this signal be strong enough to control 6 or 7 fans? Voltage would be taken from psu through butchered molex connector. CPU fan would still be connected to header and only PWM signal would be spliced.
I need to get some new fans and the only ones available here i like are the Artic Cooling PWM ones that allow PST and the Thermalright ty-120. I've got space for 3 of each. I'd like to be able to control all of them with PWM off cpu header (without blowing it up) or leave the arctic cooling ones connected to the header using PST and control the thermalright ones with voltage (i cannot find an affordable PWM controller in my country)
NOTE: i will not be splicing the fans or their cables directly. I've got a bunch of extension wires lying around i can butcher then connect in series to the fans.
Any advice or insight welcome.
To sum up:
1) Will a PWM fan work with voltage control?
2) If you splice only the PWM signal off the CPU header is it powerful enough to control several fans?
P.S: very limited fan selection here so these ones are pretty much the only ones worth mentioning. No Yate Loons/scythes/etc...
To sum up:
