[SOLVED] 4pin fans to PWM hub
Sep 28, 2021
6
I have 3 noctua 4-pin case fans. I want to put them inside my be quiet 802 case which has a 4 step integrated PWM hub (6x 3-pin).
I’ve know that 3-pin fans work with 4-pin headers, without one of the pins obviously, but does a 4-pin fan work on a 3-pin header and if it is compatible which hole needs to be left empty?
mid it helps my motherboard is ASUS prime x570 pro.
Thanks,
