I have 2 4pin molex fans and they run really REALLY slow, it is possible to make them run faster?
Thanks for the reply, i guess i'll buy a controller fanThey shouldn't since their speed is determined by the voltage which for molex is 12. The only way to control those types of fans would be via fan controller or resistor.
What are the fans make and model?
What are the fans rated for? There should be a stick on them.
The sticker says that they're 12v fans. They're maded by Ezdiy-FabIf they are running slow a controller wont make them run faster is what I mean. As I said the fans could be "quiet" fans that run at a slower speed due to a built in resistor.
What does the sticker on the fans say?
I have a sharkoon 600w and yes the fans are directly connected to the power suply and im not using any adapterWhat PSU do you have?
How are the fans plugged in? Is it directly plugged into a molex out on the power supply? Are you using a SATA to Molex adapter?
