4pin power supply cable with a 8pin on mobo for CPU HELP will it work!!!
noahcs
9
I am building my brothers PC and I have run across a problem the CPU cable is a 4pin but the motherboard is a 8pin will it still work (NOT OVERCLOCKING)
PSU-Powerspec 430watt (MICROCENTER BRAND)
CPU-Ryzen 3 2200G
GPU-NONE
Hard DRIVE- 1tb
Ram- 8gb of DDR4
Motherboard- AsRock AB350M Pro4
Need Anwsers quickly thanks!
SO will it still be able to game without any problems? And will it damage any componets?
I read it and it seems the sytstem should work fine and my cable is plugged in on 1 and 5 so i suppose it should work fine your thoughts?
