Hello guys,😀
I have read a lot of similar questions but let me ask you something more...
The good old staff: my new mobo has a 8pin connector,but my psu has a 4pin connector.
I dont want to risk and plug the 4pin to the mobo as it is,so i search the web for a solution(except from buying a new psu
The most common answer is a 4pin to 8pin converter like this:
http://www.ebay.com/itm/ATX-4-Pin-male-to-8-Pin-Female-EPS-Power-Cable-Adapter-/110718428920?pt=US_Power_Cables_Connectors&hash=item19c75526f8
But i found also this:
http://www.ebay.com/itm/12V-Molex-4-to-8-pin-Desktop-PC-PSU-Supply-to-Motherboard-ATX-Power-Lead-Cable-/171202502834?pt=UK_Computing_CablesConnectors_RL&hash=item27dc76e0b2
I think that the second converter can handle more power,as each molex will connect to two separate cables coming from the power supply not one.
Which is the best solution,so i wont having any power problems even if i o/c my hardware?
