4TB HDD help!
discodancepant
I made a mistake and initialized my 4TB HDD without putting it in RAID first. The hard drive in now sepperated into two partitions, one 2TB and one about 1.6TB (so it's not a full 4TB I guess)
The format was MBR. I tried converting the partition to GPT, but it still only shows either the 2TB or the 1.6TB in bootable partitioning tools. I tried changing to raid, but with the single HDD installed, the RAID array creation menu doesn't even appear.
Does anyone have any ideas of what I should try next? Or have i botched a perfectly good 4TB HDD?
No, delete both partitions and see if the RAID will take it raw, if not reformat it as GPT.
THe 'loss' of drive space isn't a real loss. YOu bought a 4TB drive, that is ~4,000,000,000,000 bytes of storage space. Since the computer counts binary instead of decimal, that doesn't quite equal 4TiB.
When I attempt to reformat, it only sees either the 2TB or the 1.6TB, it never shows both. When i convert to GPT, it still says only the 2TB or the 1.6TB, hiding the other.
When i reboot, the RAID manager screen doesn't even come up unless I install a second hard drive. When i configure a RAID array with the new second hard drive (1.5TB) it will only grant me 3TB total.
